5jamjwji8 Posted December 9, 2015 Share Posted December 9, 2015 Just acquired a used POD PRO HD X. Trying to use it straight into my Mesa power amp. So I set the output setting to combo/stack power amp. But when I dial up an amp pre model, it still has a cab and mic setting assigned to it. What am I doing wrong? Quote Link to comment Share on other sites More sharing options...
redmonda Posted December 9, 2015 Share Posted December 9, 2015 By default, it continues to select the default cab and mic when you pick an amp (pre or not). You can change the cab selection to "no cab" and it will get rid of the mic as well. Quote Link to comment Share on other sites More sharing options...
Dutchguitarist Posted December 10, 2015 Share Posted December 10, 2015 By default, it continues to select the default cab and mic when you pick an amp (pre or not). You can change the cab selection to "no cab" and it will get rid of the mic as well. Interesting, I know how to disable the cab, but I cannot figure out how to disable the mic. How did you do this. because I aways have a mic present (POD HD PRO) and it also affects the tone. Quote Link to comment Share on other sites More sharing options...
5jamjwji8 Posted December 10, 2015 Author Share Posted December 10, 2015 Interesting, I know how to disable the cab, but I cannot figure out how to disable the mic. How did you do this. because I aways have a mic present (POD HD PRO) and it also affects the tone. Yeah, I notice the same behaviour. I can disable the cab but the mic is always on and it does affect tone. I'm a Axe FX guy that is trying to learn this POD HD Pro X intereface. In the Axe we can globally disable the Cabs/mics and/or the power amp sims to fit whatever situation you are using the device. So now I just turn off the cab in the preset I'm going to use with the power amp. I'd also like to turn off the mic sim to but can't figure out how. Quote Link to comment Share on other sites More sharing options...
jackhammer111 Posted December 10, 2015 Share Posted December 10, 2015 If you disable the cab the preselected mic becomes disabled because a mic without a cabinet is moot. I tried disabling the cabinet within a preset and although there still appears to be a mic in the edit window, changing mics does absolutely nothing because it is bypassed. Try changing mics when the cabinet is active vs No cabinet. You should see the difference. Quote Link to comment Share on other sites More sharing options...
redmonda Posted December 10, 2015 Share Posted December 10, 2015 For more information, see Meambobo's guide regarding this topic here: http://foobazaar.com/podhd/toneGuide/setup#outputModes If you haven't seen it before, that guide has a LOT of information. Quote Link to comment Share on other sites More sharing options...
