jamminforever 2 Posted July 29, 2013 I use the POD HD 500 with my mesa mark V for effects only via 4 cable method. I've set the volume levels correctly so that when I switch my EFX pedal on my mesa Mark V switch on and off, the volume levels are consistent. For what ever reason, the volume levels will change during playing. For instance, when I disengage my effects switch on my mesa pedal board, the volume is much louder. When engaging the pod thru the loop again, the volume is softer. Is there something that I should be aware of with an issue such as this? Quote Share this post Link to post Share on other sites
silverhead 8,809 Posted July 29, 2013 I would investigate the FX Send/Return levels on both devices. Perhaps some adjustments there could normalize the levels. Quote Share this post Link to post Share on other sites
jamminforever 2 Posted July 29, 2013 If I were to turn up the volume on my amp, would that leave my fx unit, when engaged at a lower volume? Quote Share this post Link to post Share on other sites
