Sign in to follow this
crespoftw
Vocal Settings w/ UX2 and Podfarm 2
So I been trying to get a decent tone through pod farm 2, but can't really decided how to improve it
Pod farm 2 effects I use (also using +18 DB because it sound really quiet)
Noise Gate
Threshold  -40DB
Decay - 19%
Compressor
Threshold  -7DB
Gain - O DB
A link to my latest commentary
I use Audacity (not sure how to get Line 6 driver to work with it properly) and use a SE electronic 2200a II microphone
If anyone could help with suggesting effect or programs, It would be very helpful
By default Audacity uses a non-compliant ASIO driver called ASIO4ALL. I strongly recommend that you avoid using ASIO4ALL  There have been many reports about performance problems when using it.with Line 6 audio devices.
Use the Line 6 driver for your UX2. Line 6 Monkey will help you download and install it. Configure your DAW to use the UX2 and its ASIO driver as the audio input/output device.
Having done that you may no longer require the 18db boost and it might be easier to get a better vocal tone in Pod Farm.
How do you configure the DAW to use the UX2. I mean my microphone didn't need 18db boost before but now it does
What DAW are you using?
All DAWs have some way to specify your audio device. It's usually in something called Audio Setup or Preferences.
Using none yet. (was thinking of using Reaper)
But when I was using podfarm months ago it didn't need any audio boost. But I did change computer's while reinstalling all my stuff
Well just installed Reaper got everything setup but the audio within podfarm still need the 18 db boost.
I reinstalled UX2 Drivers and Pod farm but still the signal is really quiet
