gabesinhorin Posted December 18, 2015 Share Posted December 18, 2015 So I've had my POD as my computer's sound card for the majority of the time I've had it, but I've had this problem where when the POD is being used as the sound card, the audio cuts in and out. This doesn't always happen but it comes come up fairly frequently, its especially annoying when recording. Have you guys got any ideas why this could be? Quote Link to comment Share on other sites More sharing options...
shredjsx Posted December 18, 2015 Share Posted December 18, 2015 I agree, I shut all background stuff down and change the settings on my PC to no sounds.... Quote Link to comment Share on other sites More sharing options...
DunedinDragon Posted December 18, 2015 Share Posted December 18, 2015 A separate question here: is the "Line 6 Audio-MIDI device Driver" a different driver than the one installed as part of the POD Edit program? I personally don't use the POD as an audio interface as I have a MOTU UltraLite as my primary audio interface, but I'm curious about why there seem to be so many problems people keep encountering with it and the precautions you guys have been advising regarding the additional USB activities should I decide to try it some day. Quote Link to comment Share on other sites More sharing options...
DunedinDragon Posted December 18, 2015 Share Posted December 18, 2015 It just seems odd there are so many problems people seem to experience with the audio interface from the POD. I've used a variety of audio interfaces over the years from a variety of manufacturers, some more stable than others depending on how well the drivers are written. I suppose much of it could be a lack of memory or processing power on the platforms given most of the users don't specify. It just gives me pause about the stability of the drivers provided by L6 since these can vary greatly from vendor to vendor. While I would agree that running other foreground tasks and applications could be an issue when recording, buffer size and number of buffers aside, general background tasks and services shouldn't typically interfere with normal ASIO driven processing on a normally functioning computer since it's a much lighter load than general WASAPI and all sound processing drivers run by election from the controlling application which places them in user space at a higher priority than system level processes. Quote Link to comment Share on other sites More sharing options...
shredjsx Posted December 22, 2015 Share Posted December 22, 2015 Download "AISO for All" to tweek it for daw programs.... Other than that, don't really know why you are having problems.... It is easy to set up usually... Call the guys at Line 6 or get a hold of your local rep through guitar center Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted December 22, 2015 Share Posted December 22, 2015 Lots of people turn off their wifi adaptor in Device Manager before doing recording as it has bursty demands on the CPU and can cause audio pops. Quote Link to comment Share on other sites More sharing options...
