dwightweeks Posted July 30, 2013 Share Posted July 30, 2013 When I record any guitars through Pod, I get a loud clean guitar sound simultaneous with whatever Pod sound I've chosen. But when I record through an existing channel with Pod off, I get the original pod sound without the clean on top. I've tried Monkey and restarting and all the usual crap. Any help out there? Quote Link to comment Share on other sites More sharing options...
Triryche Posted July 30, 2013 Share Posted July 30, 2013 Check out the POD Farm mixer view. There are 4 sends. You can chose what to send to your DAW, Processed, Dry Input or Semi-Processed Depending on if you have POD Farm 1 or 2 it may be named slightly different. If you have the POD Farm plug-in a typical workflow is to capture wet and dry to different tracks simultaneous then add the plug-in to the dry track post processing. Quote Link to comment Share on other sites More sharing options...
dwightweeks Posted July 31, 2013 Author Share Posted July 31, 2013 All I have is Tone A, Tone A (semi), Dry I've tried all and nothing helps. Quote Link to comment Share on other sites More sharing options...
Triryche Posted July 31, 2013 Share Posted July 31, 2013 So I'm assuming this is POD Farm 2? What DAW are you using? Quote Link to comment Share on other sites More sharing options...
