higs16 Posted December 23, 2015 Share Posted December 23, 2015 Does anybody know how the 50 watt EVH5150III footswitch signals send I would like to use the helix to control channel switching. Also the new LBX 15 watt Quote Link to comment Share on other sites More sharing options...
fester225 Posted December 23, 2015 Share Posted December 23, 2015 Here is a thread already on it http://line6.com/support/topic/17343-midi-commands-with-5150-iii/?do=findComment&comment=128192 Quote Link to comment Share on other sites More sharing options...
tmntshredder Posted December 23, 2015 Share Posted December 23, 2015 Does anybody know how the 50 watt EVH5150III footswitch signals send I would like to use the helix to control channel switching. Also the new LBX 15 watt You can accomplish this by connecting a MIDI cable to the Helix and your amp. However, the onboard channel switching of the Helix will not work with the 5150III. Quote Link to comment Share on other sites More sharing options...
higs16 Posted December 23, 2015 Author Share Posted December 23, 2015 Thanks I thought I could use a TRS cable. I thought tip to sleeve or ring to sleeve or tip and ring to sleeve would work I'll try the midi. Quote Link to comment Share on other sites More sharing options...
tmntshredder Posted December 24, 2015 Share Posted December 24, 2015 Thanks I thought I could use a TRS cable. I thought tip to sleeve or ring to sleeve or tip and ring to sleeve would work I'll try the midi. The 5150III uses momentary switching, so it is not compatible. Fortunately, the MIDI switching works quite well. Quote Link to comment Share on other sites More sharing options...
higs16 Posted December 24, 2015 Author Share Posted December 24, 2015 I did use the midi with a m13. I thought the helix had the option to make a switch momentary or latching. Quote Link to comment Share on other sites More sharing options...
