Sign in to follow this
vxjoe
FX controller request
It would be beneficial for the FX "controller" section in the 500X to add a footswitch parameter to allow the control of the speed function when using the rotary drum and horn (Leslie).
So far the programming allows Exp 1, Exp 2, Variax volume, Variax tone or off. I have gotten the pedal to control speed from parameter zero to 100, (using exp 1 or 2 reserved for the pedal) allowing a varying speed for the Leslie effect.
To be clear, I am requesting the addition of selecting a footswitch (in addition to the exp 1 and 2, Variax tone or volume or off) to select the drum/horn speed from slow to fast. I have also heard that plugging in an external Expression pedal may do this. As would an on off switch plugged in to the external expression switch on the rear. I do not wish to add another external item, or I would use outboard volume and a Cry Baby pedal to free up the internal exp 1 and 2.
Thank you
You could have two instances of the effect, one faster and one slower, and switch between the two
I agree with this post. I'd like to see this applied to the volume settings for amps. I tend to use dual amps on 1 patch and find that when turning on and off the amps there is a delay before they switch. I've corrected it by adding a volume pedalike before each amp but that takes up extra blocks
