janwvdk
Is it possible to Toggle between Modulation (EXP 1) and Wah (EXP 2)?
I have assigned Expression Pedal 1 to a modulation effect and Expression Pedal 2 to Wah. I also assigned an external control pedal to volume (Expression Pedal 3). I did this to always be able to control the maximum volume, either when the wah is switched off or on.
When I toggle between EXP 1 and EXP 2 it still switches between volume and wah (the volume pedal is switched off and the wah pedal is switched on, and vice versa), although volume is not assigned to EXP 1. The modulation effect (EXP 1) is not switched off when I switch to wah (EXP 2).
In summary:  I want to be able to assing blocks to EXP 1 and EXP2 to toggle between (switch one block off while the other one is switched on). This only seems to be possible with volume and wah, I did not find a way to change it.
Is this possible? Am I overlooking something?
