Dream Rig Recording
I've been experimenting with recording with my DT25/HD500/JTV rig, and I've found success for tones I'm looking for.
Here's my setup:
Pod and DT connected via L6 link.
XLR cable from the Cab Out on the DT25 into soundcard.
At first, I thought this setup would sound pretty much like a Pod direct. I had read some things over the years here on the forums that led me to believe that if you use the Cab out on the DT25, that would be adding the same sort of simulation with going direct from the Pod itself.
The key for me is the DT setttings that allow me to customize the tone more. In particular, playing around with topologies has proved interesting, as well as trying out Class A and Class AB.
I've attached a shortHD500 and DT25 Cab Out.wav clip. The Patch is just the 75 amp with a Blackbird cab and a tube drive pedal. The guitar is JTV model Lester 1.
