Sign in to follow this
Smashcraaft
Flash Memory unknown - update stops with code 80007104
Monkey tells me, that Flash Memory installed is unknown - update stops with code 80007104
The Editor isn´t working to, giving me back an Code 80000000
I´ve tried doing the update in Safe Mode
  • holding down the "right side" of the directional selector and power up the Pod (leads to some "overview")
  • holding down the "down side" of the directional selector and power up the Pod (leads to "Update Flash").
I´ve tried the original USB-Cable and another one.
I´ve tried to click "NO" when it asks you the keep the current patches.
Please help me ASAP!!!
Computer-Details: OS-X El Capitan 10.11.2 (15C50)
Was the unit working fine before and you were just updating the flash memory or was there a problem that you tried to resolve by reflashing the memory?
I don't have a Mac so my help is limited there, but you could uninstall the L6 software and redownload/install everything. Try again. A few thing bung up the flash process - cables, usb hubs and old drivers.
You could try using a different computer if you have access to one (preferably with a different OS) just as a way to check the HD.
If all else fails -> shoot in a support ticket to L6.
-B
Thank you all. I fixed the problem using another USB-port on my iMac (used the first one now). There seems to be differences on different ports (maybe in power-supply).  :huh:
And please excuse my poor english  ;)
Different ports can do that. For example on a desktop the front ports are usually on a USB hub which L6 gear doesn't work with.
Glad it worked out.
-B
