marz25000 Posted January 1, 2016 Share Posted January 1, 2016 hi I am trying to connect a pod v2 fbv model to my laptop to use gearbox but it seems to have problems connecting it I can get the pod v2 icon show up left hand side In monkey and gearbox I have also tried to use edit but it says the pod is busy also I want to update eprom from 2.52 to v2.54 so I can get a floor controller but when I try it says code 8000900c timed out the pod is booted holding midi and displays f: is that because it hasn't connected properly using usb midi cables any ideas please ? code 8000900c timed out Quote Link to comment Share on other sites More sharing options...
Mr_Arkadin Posted January 2, 2016 Share Posted January 2, 2016 Are you using a cheap USB to MIDI cable by any chance? Those no-name units are notorious for not working. Also Pod 2.0s do not use GearBox to edit with. You will need Line 6 Edit. Quote Link to comment Share on other sites More sharing options...
BillBee Posted January 2, 2016 Share Posted January 2, 2016 Yep its probably the #1 cause. The cheap cables seem to let short data transmissions through but not the longer messages. Quote Link to comment Share on other sites More sharing options...
sirbotts Posted February 9, 2016 Share Posted February 9, 2016 I've tried different cables; same error code. Quote Link to comment Share on other sites More sharing options...
