jhachtel Posted February 3, 2016 Share Posted February 3, 2016 I am using the Amplifi FX100 in live situations now until I can put my live rig together. I expect to have some longer cable runs in the near future, ones which I would normally be inclined to use a buffer pedal. Is the FX100 a "buffered pedal"? If not, where should I put the buffer, before or after the FX100? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
NBell Posted February 18, 2016 Share Posted February 18, 2016 Hi there, Buffer's are great when using complex rigs, and pedal boards where certain effects may take away from the signal, so a soft boost or 'buffer' is used to bring that signal back up. Unless you're planning on running hundreds of feet of cable, using a buffer with the FX100 would not be needed. Quote Link to comment Share on other sites More sharing options...
jhachtel Posted February 18, 2016 Author Share Posted February 18, 2016 Ok, good to know. I will not likely be running hundreds of feet; More like 50 feet. Quote Link to comment Share on other sites More sharing options...
