jhachtel
Amplifi FX100 & Buffer Pedal
I am using the Amplifi FX100 in live situations now until I can put my live rig together. I expect to have some longer cable runs in the near future, ones which I would normally be inclined to use a buffer pedal. Is the FX100 a "buffered pedal"? If not, where should I put the buffer, before or after the FX100?
Thanks in advance!
Hi there,
Buffer's are great when using complex rigs, and pedal boards where certain effects may take away from the signal, so a soft boost or 'buffer' is used to bring that signal back up.
Unless you're planning on running hundreds of feet of cable, using a buffer with the FX100 would not be needed.
