4 Cable Method - Send/Return blocks
mikeyselb
Technically it doesn't matter but in practical terms you want to position the FX Loop in the signal chain at the point where you imagine the external device (e.g physical amp) to be placed. In other words, place the FX Loop after your pre-amp FX (typically overdrive, compression, distortion, wah,...) and before your post-amp FX (typically chorus, delay, reverb, ...).
