Sign in to follow this
EOengineer
Ac30 For Frfr Players
Weirdest thing. The AC30 is one of my favorite models when playing through my headphones (Sony 7506). It's bright, and jangly, with that super snappy midrange vox thing...but I just can't make it happen through my RCF 312A. Just getting dull, spitty raspy crunch with the "on the verge of breakup and slightly past" type tones I usually associate with the AC30.
Anyone using it FRFR? My deluges, park75, and rectifier tones sound GREAT. I've rolled the bass back a bit, brought the "cut" up, tried different mic options. I'm a bit confused.
Are you using Full or Pre Amp Models? is this a pre made preset you Downloaded? Try Creating one from scratch setting the Amp Tones without any Fx at first. Also check the Output mode on the HD500.
Also, Something that I just learned myself, Try creating a Preset with the actual setup and at the actual level you plan to use it.
I use my HD500 with a JBL PRX600, I Get Great AC30 Sounds.
Hope this Helps.
I probably should have mentioned that I'm a POD veteran. I appreciate the suggestions though, those were all things a verified prior to posting.
I build all my patches from scratch, and am shocked that I cant get what I'm looking for out of the AC30. So weird. Maybe I should post a sample, though I doubt that's going to help much.
I hear you man!
I have been a Long time Line6 Enthusiast/User as well and I still run into a lot of weird hard to figure out situations.
Good Luck to you.
