Line 6 POD HD500X Presets Volume
wayneblue
There are several presets that i would love to use.But, it seems that you can not control the volume, by the foot pedal..And when i add the volume pedal (FX block), i still can not control the volume, by the foot pedal..Any ideals on how to do this??
Have you set up the Vol pedal correctly?
Click the pedal toe switch to select Vol (Green LED)
Pick the Volume Pedal effect and move it to the front of the effect chain
Save selected
Now go to Mixer and select Volume Pedal in Model and EXP TOE SWITCH in FS Assign.
Parameter should be set to VOLUME
Make sure that Minimum = 0% and Maximum = 100%
Check that Green LED is on and EXP-2 is the selected Controller.
Save
Hopefully, that should sort it out.
Many of the difficulties you've been posting about are basic functionality topics that are all covered in the manual. I know the POD isn't the most intuitive device in the world, and manuals are not exactly a "fun read", but you'll save yourself a lot of time by going through it, rather than waiting around for someone to answer you every time you get stumped.
Load good sounding patches from CustomTones, watch Tutorial-Videos to the POD, read the MeAmBobbo Guide, use the search-function here in the community.
+1 for MeAmBobbo, it's a great resource. Customtone, imho is a dead end, but as always ymmv.
Save selected
Save
Thank you so much.I figured it out..
