gpicard5 Posted March 13, 2016 Share Posted March 13, 2016 This may have been covered but I can't find anything. Currently there are only 3 "wildcard" slots for effects. For example I can assign OD, Chorus and Octave. The rest of the blocks are fixed (Reverb, EQ, etc). IS THERE ANY PLAN for updating software so that this changes? For example, I could care less about having a dedicated FS for reverb as I am a Bassist and don't ever use Reverb! I'd rather be able to assign 2 OD's then Mod and then Filter. Thanks, -GRP Quote Link to comment Share on other sites More sharing options...
AParedes Posted May 13, 2016 Share Posted May 13, 2016 Sometimes there are limits to what a processor can do, so it may have been the only way to make it work for most applications (but the three wildcards can be changed to allow for multiples of the same effect if you want). However; your request can be submitted on ideascale so the developers are aware if your need. Quote Link to comment Share on other sites More sharing options...
howarddavidp Posted January 26, 2017 Share Posted January 26, 2017 I posted this same ask in the Firehawk section, I wanted the 4th FLEX block. On the Firehawk, which seems similar, you can unofficially get a patch that has 4 Flex blocks from an earlier firmware release, the edit and saves it yourself. If we can convert Firehawk patches, I can try and convert, which will get us 4 flexible blocks. The tone/patch is called "BJ Clean 1" under the Firehawk remote when you search the cloud for tones. David 1 Quote Link to comment Share on other sites More sharing options...
JamieCrain Posted February 16, 2017 Share Posted February 16, 2017 ... you can unofficially get a patch that has 4 Flex blocks from an earlier firmware release, the edit and saves it yourself...The tone/patch is called "BJ Clean 1" under the Firehawk remote when you search the cloud for tones. David Legend! Quote Link to comment Share on other sites More sharing options...
cush4x Posted February 22, 2017 Share Posted February 22, 2017 I use this patch as the base for all my future mods. I have not noticed any "processor" issues..... Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted February 22, 2017 Share Posted February 22, 2017 I don't use it unless I really need that extra effect, just in case it decides to throw a wobble mid gig, however, I haven't had any issues on the patches where I have used it Quote Link to comment Share on other sites More sharing options...
