Airport Express And Stagescape
So I've read conflicting things here about this. Line 6 says that the light on the Airport express must not be blinking amber. But another guy posted that you have to put the thing in DHCP/NAT mode, not bridged mode. I have another regular Airport/timecapsule and I want the airport express to just be stand alone, no internet.
So, I set it up in DHCP/NAT mode and the light is blinking amber. I do not want this thing to be an extension of my other Airport/timecapsule. I just want to use it with the mixer. The mixer is coming tomorrow, so I'm a bit ahead of myself. Just looking for a definitive answer on the proper settings for the Airport express.
Right now I have it named, with WEP personal, password and in DHCP/NAT mode as mentioned.
Thanks
I believe my light blinks amber when connected. I will double check. I think green is when it has an Internet connection....which mine never does.
Basically, it was plug and play. I had been using mine for something else. I did a "reset" by holding down the little button. Then all I did to set it up was change the name to "stagescape" and put a password on it. I didn't change any other settings. Works great.
I meant to add- both of those steps were optional. Like Arne says, it works right out of the box.
