ajm583 Posted March 20, 2016 Share Posted March 20, 2016 Hello there, I picked up a new Helix the other day and I am running it through my Egnater Renegade head using the 4cm. I am pretty green with the whole 4cm and I am experiencing an strange issue. I set up the Helix top path with a few effects and a send and a receive, no amp models or cabs, just using my amp distortion. On my dirty channel when I start playing I am hearing 2 guitar sounds, 1 is distorted and 1 is clean? I am not sure what I am doing wrong and I am not sure if the Egnater Renegade effects loops is series or parallel (if that even matters). Any help would be appreciated. Thank you in advance. Quote Link to comment Share on other sites More sharing options...
tmntshredder Posted March 20, 2016 Share Posted March 20, 2016 Check your settings on the mix of our FX loop block or return block. It sounds like you may have it set below 100%, which will cause issues. Quote Link to comment Share on other sites More sharing options...
vmoncebaiz Posted March 20, 2016 Share Posted March 20, 2016 Or you can set the dry through on the send block all the way down. Either way its just making it so you only get one signal going through instead of one going through the send/return and another going straight through and getting blended. Try splitting the paths like this for more room. http://line6.com/customtone/tone/1604598/ Notice the output on path 1 is set to XLR to avoid and dry thru or double guitar signal issues. There are a bunch of ways to go about doing the same thing. Quote Link to comment Share on other sites More sharing options...
ajm583 Posted March 24, 2016 Author Share Posted March 24, 2016 Thank you for the info, I will give it a try. Quote Link to comment Share on other sites More sharing options...
