nippyjun 23 Posted March 20, 2016 Hello I'm considering purchasing a helix. I currently own a digitech ipb-10 and thought I would like to try the helix. I need to be able to send the audio from my iPad to the helix so that both the iPad audio and my guitar sound are both outputted together to my amplifier. Is there a way to do that? Would the AUX IN be the port I use to hook up my iPad? If yes what type of connector would allow this? Thanks. Quote Share this post Link to post Share on other sites
spikey 699 Posted March 20, 2016 Dunno about other ways (sorry), but If you are running Helix into a Firehawk 1500, you can do that via the bluetooth editor on the iPad/iPhone! Quote Share this post Link to post Share on other sites
malhavok 137 Posted March 20, 2016 You can use aux in, returns, or some other fancy tricks (like USB) but in any case all these options will require you to "wire in" a signal path to output that audio. It's not an automatic thing. Quote Share this post Link to post Share on other sites
hideout 193 Posted March 20, 2016 You can use aux in, returns, or some other fancy tricks (like USB) but in any case all these options will require you to "wire in" a signal path to output that audio. It's not an automatic thing. Not USB - wrong connector type. The iPad wants to connect to a USB A (female) connector. The Helix's USB connector is a "B" connector like those found in printers and audio interfaces. He'll have to use the Aux In and sum the iPad's signal to mono. That's the simplest route. Or, for the complicated route, create two effects return blocks and two pan blocks (L/R) for stereo. Each Return and Pan block would of course have its own path - Path 1a and 1b. Quote Share this post Link to post Share on other sites
mykejb 29 Posted March 20, 2016 I'd guess going from the iPad 3.5mm output into the Aux of the Helix would work as that's standard audio. It looks like you can from the manual if you're using USB too. P20 - "Helix also receives input from USB 1/2, but it's dedicated for monitoring audio from your computer (or iPad®) and bypasses all processing blocks" The routing diagram on P45 shows USB 1/2 being routed directly to the Helix output section so it looks like it should work as long as you don't want to process the output. Not tried this as I don't have a Helix, although if I get a good deal from my guy at DV247 tomorrow I might have one soon :) Mike Quote Share this post Link to post Share on other sites
silverhead 8,865 Posted March 20, 2016 .. P20 - "Helix also receives input from USB 1/2, but it's dedicated for monitoring audio from your computer (or iPad®) and bypasses all processing blocks" ... Note that you also need the Apple camera kit in order to use an iPad with Helix. Quote Share this post Link to post Share on other sites
Ka5par 22 Posted March 20, 2016 Not USB - wrong connector type. The iPad wants to connect to a USB A (female) connector. The Helix's USB connector is a "B" connector like those found in printers and audio interfaces. He'll have to use the Aux In and sum the iPad's signal to mono. That's the simplest route. Or, for the complicated route, create two effects return blocks and two pan blocks (L/R) for stereo. Each Return and Pan block would of course have its own path - Path 1a and 1b. No need to create blocks for this, just select returns 1/2 or 3/4 as stereo input. 1 Quote Share this post Link to post Share on other sites
hideout 193 Posted March 21, 2016 No need to create blocks for this, just select returns 1/2 or 3/4 as stereo input. Oh, yeah. I forgot about that! Quote Share this post Link to post Share on other sites
malhavok 137 Posted March 21, 2016 Not USB - wrong connector type. This is incorrect. You can use USB. It requires something like the CCK. It's the standard way you connect a USB camera, USB midi keyboard, or Helix, to an iPad or iPhone. http://www.apple.com/shop/product/MD821AM/A/lightning-to-usb-camera-adapter Quote Share this post Link to post Share on other sites
nippyjun 23 Posted April 5, 2016 This is incorrect. You can use USB. It requires something like the CCK. It's the standard way you connect a USB camera, USB midi keyboard, or Helix, to an iPad or iPhone. http://www.apple.com/shop/product/MD821AM/A/lightning-to-usb-camera-adapter Once I connect the ipad via usb can I control the volume of the ipad's output? I believe you can't control the ipad's volume once you use the camera connection kit. Can you control the volume in the helix itself? Quote Share this post Link to post Share on other sites
malhavok 137 Posted April 5, 2016 If you're going to spend money to make this happen you'll get far greater mileage from a small mixer. Even something like http://www.sweetwater.com/store/detail/502would give you far greater flexibility. Both Helix and iPad plug into the mixer and the mixer plugs into your monitoring system. You're then able to mix at will with the flexibility to add a few other sound sources like computer, other people's Helix, etc. I don't use the USB input on my Helix so can't comment on controlling the volume from there. Quote Share this post Link to post Share on other sites
HonestOpinion 1,012 Posted April 6, 2016 Hello I'm considering purchasing a helix. I currently own a digitech ipb-10 and thought I would like to try the helix. I need to be able to send the audio from my iPad to the helix so that both the iPad audio and my guitar sound are both outputted together to my amplifier. Is there a way to do that? Would the AUX IN be the port I use to hook up my iPad? If yes what type of connector would allow this? Thanks. A simple solution would be to use the min-jack (3.5) headphone output on the iPad with a commonly available cable that goes from mini-jack and splits to two 1/4 male connectors. Just plug these into two return jacks and you will have a stereo input. You would then set up an input block and path that uses the returns you plugged the iPad into. Set the output block for the iPad path to whichever output you are using for your guitar amp. If you wanted an even simpler method, and don't care if the iPad is in stereo, you could use a mini-jack to 1/4. stereo out of the iPad headphone summed to a single mono 1/4 output plug. As you are going out to a guitar amplifier you probably want the iPad summed to mono anyway. I think this should work just fine. Mono to a single return input http://www.sweetwater.com/store/detail/CMP110?adpos=1o1&creative=54989267161&device=c&matchtype=&network=g&gclid=CLLzvdmE-csCFRJZhgodys0ADQ Stereo to two Helix return inputs http://www.sweetwater.com/store/detail/CMP153 Quote Share this post Link to post Share on other sites
nippyjun 23 Posted April 18, 2016 No need to create blocks for this, just select returns 1/2 or 3/4 as stereo input. I was looking at this thread again. I have connected my iPad to the helix using a 1/8" to 1/4" cable and run it to return 1 on the helix. I then create a return 1 block in the patch and fiddle with the settings and it works well. But what did you mean by "no need to create blocks for this, just select returns 1/2 or 3/4 as stereo input"? Is there a setting that for every patch I wouldn't have to create a return block? That would be great. Is there a stereo input global setting? Thanks. Quote Share this post Link to post Share on other sites
roscoe5 254 Posted April 18, 2016 +1 to using the Apple "camera" adapter and leveraging audio back on USB 1/2. Unless you were wanting to add effects to the audio. Quote Share this post Link to post Share on other sites
nippyjun 23 Posted April 18, 2016 +1 to using the Apple "camera" adapter and leveraging audio back on USB 1/2. Unless you were wanting to add effects to the audio. But can you control the iPad volume with this method? Quote Share this post Link to post Share on other sites
Ka5par 22 Posted April 18, 2016 I was looking at this thread again. I have connected my iPad to the helix using a 1/8" to 1/4" cable and run it to return 1 on the helix. I then create a return 1 block in the patch and fiddle with the settings and it works well. But what did you mean by "no need to create blocks for this, just select returns 1/2 or 3/4 as stereo input"? Is there a setting that for every patch I wouldn't have to create a return block? That would be great. Is there a stereo input global setting? Thanks. Not a global setting unfortunately. Navigate to a input icon and you can change the input source. This is a setting for each patch separately. Quote Share this post Link to post Share on other sites
GeeTah 19 Posted April 20, 2016 But can you control the iPad volume with this method? You cannot control the output volume of your iPad using the iPad Camera Kit and connecting it to your Helix via USB. Said another way, the output volume controls of the iPad are disabled when using the Camera Kit. Quote Share this post Link to post Share on other sites
nippyjun 23 Posted April 20, 2016 Hi, Thanks for all the responses. I received my Camera connection kit yesterday. I got the new one that is usb 3 compatible (not that it matters) and it works fine. As stated above you cannot change the volume but the volume is actually quite loud which for the most part works for me. I also had gotten a 1/8" to 1/4" cable to connect the ipad using the headphone jack and connecting that to one of the returns on the helix. With this method I have to add a return block to each patch but I can control the volume either through the ipad volume control or using the settings for the return block. So more flexibility with this method but more work. The usb method is easier but less flexible. The other thing I want to mention is that with the camera connection kit the sound automatically passes through to the helix and out to my amp without having to do anything. It just does that automatically. Quote Share this post Link to post Share on other sites
jbuhajla 326 Posted November 19, 2016 But can you control the iPad volume with this method? Yes. Global settings, inputs/outputs, USB 1/2 volume. Quote Share this post Link to post Share on other sites
besully926 1 Posted August 14, 2017 According to the Helix 2.0 manual, the Aux In is designed to be used as an input for guitars with active pickups. If you plug a iPad here you will hear the patch's effects, including distortion, in playback. Quote Share this post Link to post Share on other sites
