Sound bleed when volume pedal at zero
whunt2
So I've searched through the threads but didn't find any discussions that specifically answered the question I have.  I'm using the POD HD400 and have a patch with a distortion effect on FX1 and a delay effect on FX3.  I've run into instances in a live setting where I only have the FX1 effect activated, I literally am muting the guitar strings, have the volume pedal in the up position, then I stomp on FX3 to prepare for using it later and a note will squeal through the house.  I have a MIM Fender Strat plugged into the POD HD400 then going into a Fender Hot Rod Deville tube amp.  I'm connecting the POD HD400 with the 4 cable method.  I just can't understand how sound comes through when I have the volume pedal up.  I thought that's the reason for the volume pedal, to prevent any sound.  If someone can help me figure this out, I would be thankful. It's caused me some embarrassing experiences when it's silent and I'm just getting ready for another part in a song and then I'm squealing a note through the house unexpectedly. Thank you.
As a general rule with volume pedals on a traditional pedalboard setup you'd put them after your overdrives / distortions / fuzzes so you don't lose any gain when the volume pedal is lower, obviously this won't fix your situation, but it's a good general tip :)
I did the pedal calibration tonight and I did make sure the volume pedal was routed in the "post" position.  I have a practice tomorrow night in the place we'll be playing Friday so I'll see how it goes. Thanks.
