Neverender333 Posted March 30, 2016 Share Posted March 30, 2016 Is there anyway to make it so the wah-pedal is completely off when in the full heel-position? I need to switch rapidly between using the wah and having it in "bypass", but every position of the pedal maintains some sort of effect. Quote Link to comment Share on other sites More sharing options...
jdebiase Posted March 30, 2016 Share Posted March 30, 2016 Not sure if this helps but you could have two identical patches assigned to two adjacent foot switches only one would have the wah engaged the other would not. You could toggle between them when you need the wah. Still a lot of tap dancing but not horrible! Cheers. Jim Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted March 30, 2016 Share Posted March 30, 2016 You do realise you can turn the wah off by pushing down on the toe? I'm only saying because I've seen a few people on here that didn't realise If the switching is too slow still because of the stiff nature of the switch you can file the rubber pads a little which makes switching easier Quote Link to comment Share on other sites More sharing options...
garry9133 Posted April 8, 2016 Share Posted April 8, 2016 My solution is to connect a second expression pedal. Assign Wah (or tweak) to that, so the on-board pedal always remains the volume control, which I believe is better as you don't have to worry about switching it over at all. I use a cheap Bespeco pedal and it's great. They are only about £15 ($20 US) Quote Link to comment Share on other sites More sharing options...
