hetrickaj 0 Posted March 31, 2016 I have a Line 6 Pod 2.0 and i am not getting any sound out of it, I am using a 1 spot power adapter with the correct adapter to fit the power slot. I am wondering if that is it? Basically when i have it plugged in and try to play any of the patches there is almost no sound except for a small amount creeping through, almost sounds like a noise suppressor but with the threshold overpowering the signal. List of stuff i have checked, tried different cables for both the output and input tried different guitars with actice and passive pickups tried both outputs (Direct/Amp) made sure the output level and drive were up turned off all effects and ran it straight through have tested on both my home studio, a tube amp and a solid state amp Can't seem to get anything out of this thing, which i do want to demo, weird thing is when i do turn on an effect like the flanger or phaser, i can slightly hear the waves happening..but still a very ultra weak signal Any thoughts? Quote Share this post Link to post Share on other sites
BillBee 397 Posted March 31, 2016 The Pod's PS is 9vAC, 2000mA, I think the One Spot is 9vDC IIRC ~ 1500 - 1700 mA. Could be the problem right there. Try it with the original PS. Quote Share this post Link to post Share on other sites
