roscoe5 253 Posted April 8, 2016 I have added equivalent Power Amp + Cab IR's on Dropbox along with the speaker-only IR's I previously made. These have a lot thicker sound and I believe have captured more of the tube power amp + cab interaction and vibe. These can be use with Helix preamp blocks as well as amp blocks. Using them with preamp blocks will allow you to split the signal after the Helix preamp block for a virtual effects loop or to send preamp signal to your real tube power amp or amp effects return, the run the Amp +Cab IR to the Helix XLR for front of house sound. Since Line 6 hasn't published separate Power Amp models & blocks, these Power Amp + Cab IR's will get you in the neighborhood of that functionality with a Helix preamp block. Maybe they will save Helix processing resources too with a preamp only block, who knows. These IR's should give you completely different sounds than Helix models and Ownhammer or Redwirez IR's. Mesa Dual Recto Pwr Amp +Cab Marshall JCM800 70 80 Pwr Amp + Cab Marshall Plexi GB Pwr Amp + Cab Fender Twin 212 Pwr Amp + Cab Fender Deluxe 410 Pwr Amp + Cab Engl Pball 412 Pwer Amp + Cab (Norm & Deep) & Cab Be sure to experiment with the Low Cut, High Cut, and 1024/2048 samples. These may distort a bit, so try turning down the Helix preamp or amp model Master level and turn up the IR level if unwanted distortion occurs. Files on Dropbox https://www.dropbox.com/sh/009bkqzooza1aop/AADhgWBm3EfcN6205-IWaGZaa/IR?dl=0 1 Quote Share this post Link to post Share on other sites
mikisb 29 Posted April 8, 2016 did'nt try out one of your IRs but i will do it soon. So, in advance: Thanks for the work and sharing the results!! Quote Share this post Link to post Share on other sites
glideman 162 Posted April 8, 2016 I have yet to actually use an IR with Helix! LoL! I'll have to download and try these. Thanks for your efforts and generosity! Quote Share this post Link to post Share on other sites
Paolo_Maina 53 Posted April 8, 2016 thank you! Quote Share this post Link to post Share on other sites
roscoe5 253 Posted April 8, 2016 Engl Cab & Engl Pball Pwr Amp + Cab added. Quote Share this post Link to post Share on other sites
willjrock 95 Posted April 8, 2016 Roscoe! what can i say dude? Youre the man! Youve got your own dedicated folder on my desktop. Thanks again. I'll give you a shout after i get a minute with the new stuff. Quote Share this post Link to post Share on other sites
