Sign in to follow this
phil_brannigan
HD300 - How to recall a preset as it was saved
Most of my patches are saved with the basic amp and reverb settings switched on, but with overdrive, a modulation effect and delay set up but switched off. So when I'm playing I'll switch those on as needed. The next time I use the patch, I want it to be in its saved state, with the overdrive, modulation and delay effects switched off. However the HD300 keeps them switched in, even if I select another patch and go back to the original one, it still has the variations switched on. Is there any way using the footswitches to recall a patch with its settings as they were saved?
Are you using the editor program on your computer while this is happening? If so, the behaviour you describe is normal. You can restore the saved settings from the device by using the Receive command in the editor. The unsaved changes are kept in the editor's buffer while you change back and forth between presets.
Editing directly on the Pod device, without using the editor, should not retain any unsaved changes while you switch presets.
