buzzalad Posted April 10, 2016 Share Posted April 10, 2016 Can anyone recommend a preset to play Creep by Radiohead please? I want to try and play both parts so need a nice clean setting and then into a very dirty one. I thought I was on to it with a dual amp/IR setup but I kept running out of DSP any help would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
willjrock Posted April 10, 2016 Share Posted April 10, 2016 You def should not be running out of DSP. Drop down to your B path if so. I think you are making some "improper" block choices. If you are just plugging the helix into your interface with 1 cable, thees no need to choose stereo anything for fx. If you are using 2 then stereo fx after cab blocks. Dont put stereo distortion before amps. If you show a block diagram, im sure somebody can point out where you went wrong. Read the routing section in the manual. Quote Link to comment Share on other sites More sharing options...
