Squeaky Expression Pedal
chuskey
My expression pedal has developed a squeak to it when rocking it back and forth.  I've tried adjusting the tension so it isn't that.
What type of lubricant should I use and where physically on the pedal should I use it?  I don't want to spray any lubricant in a spot that could cause any issues, if that's even possible.  I haven't opened up the case, so I don't know how the expression pedal is connected to the circuit board.  Just want to get rid of the squeak safely :)
Thanks!
