cooperfloyd
Assignable Expression Pedal on M9?
I don't have an m9 but I am looking at getting one. Since there are two expression pedal inputs (I am not using it for a volume pedal or wah or anything), can I assign a pedal to control something such as reverb decay or mix?
Totally!
With the M9 it quick saves. So pretty much you will place the EXP at the heel position, set any parameter of any effect to where you want it, then set the EXP to the toe position while setting the parameters to where you want them and thats it. You'll see the parameters change when rocking the EXP.
