Taping Helix to Board
Bikedude
I've seen one guy for sure use the Scotch double sided tape to safely stick the Helix on a pedalboard. My question is, maybe I missed it, is it ok to take the feet off, and then re use the screws before taping?
Given the weight of the Helix and the physics of inertia, I'd be nervous about just using tape to hold down my Helix. Industrial strength velcro, perhaps.
I used bungee cords like these (cut in half, with each half screwed down): http://www.farmandfleet.com/products/567489-progrip-stretch-lock-bungee-cord.html.
There are all sorts of small bungees available, and if you use the ones with hooks you can mount screw-eyes in your board to fasten them to. Easy on, easy off. Leave the feet on for friction.
Given the weight of the Helix and the physics of inertia, I'd be nervous about just using tape to hold down my Helix. Industrial strength velcro, perhaps...
Industrial strength Velcro is only as strong as the backing tape it uses.
