Squeaky Foot Pedal Easy fix
Aceaj78
I had the dreaded squeaky pedal and I fixed it very easily, I loosened the tension bolt with the wrench until the pedal was real floppy. I took a knife and coated the end with grease. I lifted the pedal up and went from thr toe end in underneath and slide the knife between the bushing and worked the grease in. I did the same on the outside. I worked up and down, tighted the bolt and it is quiet now. It took 5 minutes.
  • Upvote 2
Excellent, definitely preferring this method to opening the chassis!
  • 1 year later...
