hideout Posted April 17, 2016 Share Posted April 17, 2016 So I did this crazy thing. I setup a patch with a Fender Deluxe (Vibrato channel), a Twin cab and here's where it gets nutty, a Valve Driver between the amp and cab. Hefty volume drop but man it sounds cool. Very greasy SRV type tone and feel. Probably going to have to put in a Gain block to boost the output level. Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 17, 2016 Share Posted April 17, 2016 There are no rules! If it sounds good, it's right. Seems it's like putting the same analog pedal in the FX Loop of the analog amp. A Drive pedal normally goes in front of the amp, but you certainly could place it in the FX Loop. Quote Link to comment Share on other sites More sharing options...
hideout Posted April 17, 2016 Author Share Posted April 17, 2016 There are no rules! If it sounds good, it's right. Seems it's like putting the same analog pedal in the FX Loop of the analog amp. A Drive pedal normally goes in front of the amp, but you certainly could place it in the FX Loop. Yes, except I'm using the whole amp less the speaker - Power amp and all just to be wacky. Gonna have to try it with just a preamp next. Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted April 17, 2016 Share Posted April 17, 2016 There are no rules! If it sounds good, it's right. Amen to that. Only problem is that some things...like this example...is so intuitively goofy that we probably miss out on lots of cool stuff, just because it makes no sense to even try in the first place. ;) But if it works, it works. Quote Link to comment Share on other sites More sharing options...
hideout Posted April 17, 2016 Author Share Posted April 17, 2016 My motto is, "When experimenting with a modeler, if you can, you should!" What would the world be if no one asked, "What if?" Quote Link to comment Share on other sites More sharing options...
bsd512 Posted April 18, 2016 Share Posted April 18, 2016 You likely voided the warranty on your Valve Driver by plugging such a high output signal into its input. I'm surprised it still work! :-) Quote Link to comment Share on other sites More sharing options...
spikey Posted April 18, 2016 Share Posted April 18, 2016 You likely voided the warranty on your Valve Driver by plugging such a high output signal into its input. I'm surprised it still work! :-) It was Helix. Had it been an HD-500 it woulda fell apart... (ducks and runs for cover...) Quote Link to comment Share on other sites More sharing options...
hideout Posted April 18, 2016 Author Share Posted April 18, 2016 It was Helix. Had it been an HD-500 it woulda fell apart... (ducks and runs for cover...) Bwaha! Quote Link to comment Share on other sites More sharing options...
