Indianrock2020 Posted April 20, 2016 Share Posted April 20, 2016 The VDI connection to POD is awesome but I haven't had a chance to try it on a stage yet. What has been your experience where there could be cell phones or odd lighting around? Quote Link to comment Share on other sites More sharing options...
clay-man Posted April 20, 2016 Share Posted April 20, 2016 Pretty sure you'll get 0 interference. The signal is strictly digital, so there is no analog interference that you could get from a normal cable, and I'm pretty sure the VDI cable is shielded inside. Quote Link to comment Share on other sites More sharing options...
Rewolf48 Posted April 20, 2016 Share Posted April 20, 2016 Never had any interference problems or noise while using Models and VDI. You might get some noise (typically hum) when using the magnetic pick-ups simply because they pick up electromagnetic noise, but the digital only route is silent except perhaps for a little hiss if you have a lot of gain in the simulated amp. Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted April 20, 2016 Share Posted April 20, 2016 You won't get interference from the VDI but you might get some in the analog chain after the pod. But if you are not getting any now, then you should be fine with the VDI and the Variax. One great thing about the Variax is that the Piezo's get little to no interference from noise sources where as Mag pickups often get lots of it. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted April 20, 2016 Share Posted April 20, 2016 What Charlie said. Quote Link to comment Share on other sites More sharing options...
