Sign in to follow this
rmp5s1
Looper changing with effects
How can I get the loop to stop being affected by channel changes?  Volume changes, tone changes, all kinds of weird stuff is happening despite being "after the amp".
HD500x -> DT50 via L6Link
If the looper is in post position (at the end of the signal chain) the playback should not be affected by patch edits/changes.
Please confirm that the looper is in post position. Note that in the looper display, the text indicates what WILL happen if you hit the footswitch. In other words, if the text display says POST that means the looper is currently in PRE position. The best indicator is to look at the position of the looper block in the main signal flow display.
