Sign in to follow this
ricksteruk
SEND Block increase functionality - easy way to route 1/4in to stage - IDEASCALE
Hi all,
I just spent a fair while reading all 32 pages of ideas and no-one seems to have though of this one so I thought I should start it off.
http://line6.ideascale.com/a/dtd/SEND-Block-to-more-places-e-g-1-4in-for-easy-IR-bypass/818624-23508
Allow the SEND and RETURN blocks to connect to more of the Helix inputs and outputs.
SEND should also go to 1/4in, XLR, USB, Digital.
RETURN should also return from AUXin, Variax, Digital, USB
This would make Helix's routing even more powerful.
Scenario 1:
A simple way to set up 1/4 in jacks to amp on stage and XLRs with Cab/IR to FOH. You could leave the Helix path output set to "XLR" and then just add a send block before your IR or Cab block that was set to send to 1/4in jack outputs. Simples!
One reason for doing this is that you don't have to use a whole Path line just simply to do Scenario1. Meaning the other Paths can be used for parallel fx routing or maybe processing a mic as well.
Of course to save a path you could connect your amp via a Send socket that you can already select with a Send block - but then you lose the ability to control the stage amp level with the Helix volume knob.
Scenario2:
Set up a USB device in a Send / Return loop easily. Think of the possibilities.......
Done !
I ran into it last weekend when I was setting patches for a guitar using a stereo cable for mag and piezo. I had figured a way to make my life easier when I discovered the send was shorter on options than I thought
Count me in!
I've been thinking about posting that idea myself.
Glad you did it, and thought of the same possibilities I had envisioned.
Create an account
Register a new account
Sign in
Sign In Now
