MrDude306
POD HD 500X PROBLEM TURNING ON!!!
My Pod just stucking in the black screen, not even logo and rebooting trick doesn't work! Looking forward to the answer what to do!
This is a tricky one...
Confirm that the power adapter is delivering the required voltage and mAh. I have had other electronic device causing a malfunction on the power adapter's load (not enough mAh).
Ideally you want to try another power supply before assuming the fault being with the HD500/X.
