rd2rk 1,042 Posted April 24, 2016 I seem to have lost input/output in path B. I'm using xlr outs to a mixer and by cable swapping I've determined that both mixer channels work, both POD xlr outs. work. No matter what I do with the POD mixer settings, no path B. Reflashed, did factory reset, no joy. Any ideas before I go to support?? Quote Share this post Link to post Share on other sites
BillBee 396 Posted April 25, 2016 Hmmm is this on all patches? What about the 1/4" outs? Are you running any stereo fx that are hard panned? And when you say you have lost "input" for path B are you saying there is no input for a separate path? Only things I could suggest off the top of my head are double check the input settings, stereo FX and mixer panning. Quote Share this post Link to post Share on other sites
Brazzy 440 Posted April 25, 2016 This is a new one to me. hmmmmm Quote Share this post Link to post Share on other sites
FrozenOzone 88 Posted April 25, 2016 I seem to have lost input/output in path B. I'm using xlr outs to a mixer and by cable swapping I've determined that both mixer channels work, both POD xlr outs. work. No matter what I do with the POD mixer settings, no path B. Reflashed, did factory reset, no joy. Any ideas before I go to support?? Same here... I have never heard of this happening? Is this happening in the HD edit program or on the device? Is this issue on all patches or just 1? Just gathering information. Also, if you have a screen shot that might help us troubleshoot it better. Quote Share this post Link to post Share on other sites
rd2rk 1,042 Posted April 26, 2016 Simple stuff Global: input 1 guitar Input 2 variax Path a - delay panned hard left Path b - reverb panned hard right Pre split - pan pedal Guitar split with ABY. Out a to amp input, out b to pod input. Xlr left to external mixer CH 1 Xlr right to external mixer CH 2 Amp fx send to external mixer CH 3 External mixer all channels panned hard right, right out to amp fx return. Pretty obvious what I'm trying to do. Keep my distorted tube pre analog and mix it with clean digital reverb and delay over which I have maximum static and dynamic control before returning the mixed signal to the tube amp's power section. I never use edit except as as a batch patch manager, less annoying and faster to edit patches on the pod itself. I never use dual amp setups, so I loaded up one of meambobo's excellent rigs, same problem. Keep thinking I've missed something simple. Have I? Quote Share this post Link to post Share on other sites
edstar1960 385 Posted April 26, 2016 I am assuming you have only got a guitar connected to the Pod. Correct? What happens when you set Input 1 to Variax and Input 2 to Guitar on Pod? (I think you will now lose sound from Path A) What happens when you set Input 1 to Guitar and Input 2 to SAME on Pod?​ (I think you will now have sound from both Path A and Path B ) Quote Share this post Link to post Share on other sites
Rewolf48 321 Posted April 26, 2016 See this thread about the routing... http://line6.com/support/topic/2033-pod-hd-500-500x-new-routing-schematics/ The important part is that Input 1 takes the top path only (A) and Input 2 takes the bottom path only (B ) unless something else gets in the way to change it. That something can be a mono effect but not stereo if you want the Input 1 to reach path B (Pan is Stereo). To get sound out of both sides either: Change Input 2 to be Guitar or Same or add a Mono Effect such as a noise gate. List of Effects Mono/Stereo properties: http://line6.com/support/page/kb/_/pod/pod-hd/stereomono-fx-list-for-pod-hd-r567 5 Quote Share this post Link to post Share on other sites
rd2rk 1,042 Posted April 26, 2016 Thanks rewolf. Originally I had a noisegate there, which is mono, and same diff with nothing pre split. Quote Share this post Link to post Share on other sites
rd2rk 1,042 Posted April 28, 2016 I figured out the problem, it was something simple. My original setup - noisegate pre-split, delay path A, reverb path B, pan pedal post split - was correct and was working fine. The problem was that the spring reverb default mix (15%),combined with the 6db loss, wasn't noticeable, even though the external mixer was set to unity gain. Turned up the mix setting on the reverb and BINGO! Reverb! I probably, as a first troubleshooting step, took out the noisegate and swapped the pan pedal to pre-split, which then cut out path B completely. Thanks, rewolf, for reminding me about that signal routing thread. Don't know why meambobo's preset didn't work. Probably by the time I got around to that I'd so confused myself that I'd turned off the channel on the external mixer and didn't notice? Anyhow, thanks all! Quote Share this post Link to post Share on other sites
Smashcraaft 40 Posted April 29, 2016 Haha. I had recognized this, too. Playing through MeAmBobbo's setlist, there was one single patch, which was nearly complete silent (maybe 1 % could be heard (or even not, could have been just imagination)). But at the time I had checked his patches , I didn't even care and got forward to the next patch. Maybe I will reload his setlist and give it a try again just for clarification. Quote Share this post Link to post Share on other sites
rd2rk 1,042 Posted April 30, 2016 Smashcraft - You know, it's been so long since I played with his patches I'd totally forgotten about that! Be hysterical if I'd been testing with his one bad patch! Quote Share this post Link to post Share on other sites
