Sign in to follow this
dzemil055
Spider Valve and FBV2 Problem??
Hi everyone..
I had a Line 6 Spider Valve 212, and when i plug in FBV2 footswitch its delay when i want to switch betwen chanels, and after that it changes randomly...
I tried FBV2 on other Line 6 amp and it worked correct...
Please help if you now something becouse i have some gig for about 10 days so i realy need help...
Thanks...
Hi everyone..
Thanks...
Maybe try this from the FBV MkII Advanced User Guide:
Page 1-7
...it is recommended that you perform the following steps to “calibrate†the pedal before putting it to use with your computer or your Line 6 Amp or POD.
FBV Shortboard MkII Calibration Steps
• Start with your FBV device not connected to any USB port or Line 6 device (and, therefore,
powered “offâ€).
• Press and hold down the “D†labeled footswitch while you “power on†your FBV (by connecting
to your computer’s USB port or Line 6 device with which you plan on using your FBV). The
LCD will read “CALIBRATE PEDAL†until the D footswitch is released, at which point it will
read “1 PEDAL TOEâ€.
• Press the on-board pedal forward fully and hold down pedal’s Toe Switch until the LCD changes
to “2 PEDAL MINâ€. This should occur instantly.
• Move the pedal to the “heel†(minimum) position. While holding the pedal in the heel position,
press & release the D button. The LCD will change to “3 PEDAL MAXâ€.
• Move the pedal to the toe (maximum) position, without clicking the Toe Switch. Allow the
pedal to rest in the toe position and press & release the D button. The LCD will change to
“CHECK VALUE 127â€.
• Move the internal pedal and verify that the LCD reads “CHECK VALUE 0†in the minimum
position and “CHECK VALUE 127†in the maximum position.
• If you happen to get different values that “0†or “127â€, then try repeating these calibration steps.
If your values are correct, then calibration was successful - power off your FBV and power it back
on and you are ready to go!
no dont work.. :(
My next step would be to try a different ethernet cable. If that doesn't work, backup all the Spider Valve patches on computer using the Line6 Monkey and Spider Valve Edit software, then update/reset firmware of the Spider Valve, then reload the patches.
Create an account
Register a new account
Sign in
Sign In Now
