Acoustic IRs
jshoenfelt
I downloaded some acoustic IRs, thanks to members here.  How are you using them with electrics?  I had my HD500 set up with an acoustic simulator going into the effects return with a volume pedal so I could "mix" electric and acoustic with the expression pedal on the HD500 being a volume pedal also.  I would like to replicate that setup minus the acoustic simulator pedal.  Any ideas?
I use those IRs with a PowerBridge. It's not really going to change an electric sound into an acoustic sound.
If you're serious about wanting acoustic sounds from your electrics, the PowerBridge is a GREAT way to go, and you can then layer two sounds.
Here's how I do it. There are a bunch of video samples in this article with quality audio.
https://pietrosquared.wordpress.com/
