wambathefool Posted April 28, 2016 Share Posted April 28, 2016 HD500 newb here. Does the order of the effect matter in chain like on a regular pedalboard? Quote Link to comment Share on other sites More sharing options...
BillBee Posted April 28, 2016 Share Posted April 28, 2016 Yes it does. BUT first google Perfect Pedal Order - Steve Vai and watch the video (its posted in the Lounge section here too). Really good information on pedal order and possibilities. -B 1 Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted April 28, 2016 Share Posted April 28, 2016 Yes...but in the modeling realm, traditional "rules" about what goes where don't necessarily apply. Just because something doesn't seem to make sense, won't necessarily mean that it doesn't sound good. Try it all... 1 Quote Link to comment Share on other sites More sharing options...
Indianrock2020 Posted April 28, 2016 Share Posted April 28, 2016 After viewing how others did this, I now use this order: NoiseGate>Compressor>Overdrive or Distortion>Parametric EQ>Amp>Mixer>Delay>Reverb>Volume Pedal The overdrive and parametric EQ are usually assigned to a footswitch so they both come on together. See Peter Hanmer's videos 2 and 3 on the 500x on how to use parametric EQ to tame ugly overdrive frequencies http://www.peterhanmer.co.za/line6.htm The volume pedal effect is assigned to Expression 1 and set to control volume -- usually going from 70% to 100% 1 Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted April 28, 2016 Share Posted April 28, 2016 But these 'modeled' effects are based on real effects, so the rules still apply. It doesn't matter if it is physical or virtual, the end result is the same. The only problem is, there are no rules. There are only starting points. The end result is up to you. In the 'old' days, I had multiple of the same pedal so that I could put it at various places in the chain. Screw the rules. Just make it sound good - which is sometimes the exact opposite of what the rules say. 1 Quote Link to comment Share on other sites More sharing options...
wambathefool Posted April 29, 2016 Author Share Posted April 29, 2016 After viewing how others did this, I now use this order: NoiseGate>Compressor>Overdrive or Distortion>Parametric EQ>Amp>Mixer>Delay>Reverb>Volume Pedal The overdrive and parametric EQ are usually assigned to a footswitch so they both come on together. See Peter Hanmer's videos 2 and 3 on the 500x on how to use parametric EQ to tame ugly overdrive frequencies http://www.peterhanmer.co.za/line6.htm The volume pedal effect is assigned to Expression 1 and set to control volume -- usually going from 70% to 100% Thank you, this was very helpful. Quote Link to comment Share on other sites More sharing options...
AlexKenivel Posted May 1, 2016 Share Posted May 1, 2016 For high gain rhythm I use the hard gate after whatever boosts. The digital delays I use after the amp, the tape echoes I use before the amp but after any overdrive stomps. Chorus, phaser, tremolos, I place either pre or post depending on how I want to use the effects. Pitch effects I place as close to first as possible, or in path b and blend with the mixer for mock 12 string sounds. Compressors I find more effective after the amps, but before of I'm using as a gain stage (which I don't really do anymore). For synth sounds I use something like the synth o matic and place it near the start of the chain like pitch effects for better note tracking Quote Link to comment Share on other sites More sharing options...
joel_brown Posted May 2, 2016 Share Posted May 2, 2016 Start normal before you get creative. 1 Quote Link to comment Share on other sites More sharing options...
duncann Posted May 2, 2016 Share Posted May 2, 2016 One of the particulars of the HD is the EQs. If you're going to use them, they tend to clip internally very easily, especially after the mixer block. So it might be better to cut frequencies rather than add them if you can. It's probably good to pay real close attention to the level you're getting after each block in the chain by using a DAW meter or something like that. 1 Quote Link to comment Share on other sites More sharing options...
joel_brown Posted May 2, 2016 Share Posted May 2, 2016 One thing I learned from doing studio work from the sound engineer was always try to cut frequencies first and only boost if you have to. That helped me a lot over the years. 2 Quote Link to comment Share on other sites More sharing options...
brue58ski Posted May 2, 2016 Share Posted May 2, 2016 After viewing how others did this, I now use this order: NoiseGate>Compressor>Overdrive or Distortion>Parametric EQ>Amp>Mixer>Delay>Reverb>Volume Pedal The overdrive and parametric EQ are usually assigned to a footswitch so they both come on together. See Peter Hanmer's videos 2 and 3 on the 500x on how to use parametric EQ to tame ugly overdrive frequencies http://www.peterhanmer.co.za/line6.htm The volume pedal effect is assigned to Expression 1 and set to control volume -- usually going from 70% to 100% Hey! Where's the chorus-flanger-phaser-univibe-wah your supposed to always have? ;) Quote Link to comment Share on other sites More sharing options...
BillBee Posted May 3, 2016 Share Posted May 3, 2016 The "chorflaseruniwah" ? Assign it to exp. pedal 3. :D Quote Link to comment Share on other sites More sharing options...
kerrywood Posted May 25, 2019 Share Posted May 25, 2019 what if iam not using distortion or over drive just the amp in the chain Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted May 25, 2019 Share Posted May 25, 2019 4 hours ago, kerrywood said: what if iam not using distortion or over drive just the amp in the chain The same applies. 1. Treat virtual like you would physical. 2. There are things that sound better before, and things that sound better after. 3. Ignore 1 and 2, and do what needs done to make it sound the way you need it. 1 Quote Link to comment Share on other sites More sharing options...
