SoCal Posted May 5, 2016 Share Posted May 5, 2016 I play a Les Paul and have made some good progress tweaking my Firehawk tones with EQ. I run direct into PA and have a Kustom powered wedge back to me. Can you provide some EQ suggestions that work well for you. Quote Link to comment Share on other sites More sharing options...
enarf24nilug Posted May 6, 2016 Share Posted May 6, 2016 Eq is one of the most important things when tweaking tone.First of all,we need to know what type of tone you want ( more/less bassy,mids or not,treble or not ).I have some tips that could help but first,tell me what is your problem and what you want! :) Quote Link to comment Share on other sites More sharing options...
SoCal Posted May 6, 2016 Author Share Posted May 6, 2016 First need to get rid of fizz and sharpness and add some warmth. The tones sound great with headphones but too harsh through the PA/monitors. Already watched the tone creation video and go some good ideas. Just need some general direction as to what frequency typically need to boost/cut. Any sample Tones on Tone Search would help too. Quote Link to comment Share on other sites More sharing options...
FiveBass Posted May 7, 2016 Share Posted May 7, 2016 Can't say much for guitar since I play bass (you know what I mean). I have a couple patterns for my custom tones with my instruments. Squelch 110, 191, and 272 to reduce harmonic ring (or 87, 247, 392). High shelf boost at 2.9KHz to maintain crispness. -76 or -48 dB gate does the rest. I did all the math tables and plots to arrive at the most effective open 2nd through 4th harmonics to dampen. The calculated numbers really shortened the time it took me to tune in the 4 band semiPEQ. I may be encouraged to try the math for regular guitar. Quote Link to comment Share on other sites More sharing options...
AParedes Posted May 7, 2016 Share Posted May 7, 2016 Hi Socal, EQ is different with every guitar as well as monitor and listening area, so there are a lot of variables to consider. I always reccomend cutting what you don't like vs. boosting what you like, to avoid adding noise to your signal. if you have having an overly "sharp" attack, try dropping frequencies in the 3-5k range and see what happens. a little EQ can go a long way, so take it in small chunks and see what happens. best of luck! Quote Link to comment Share on other sites More sharing options...
