phenix9 2 Posted May 10, 2016 hi i have the G30 but i can't play 8 hours with it i will say just 2-3 maximum and you? i have seen the g 10 is it better? Quote Share this post Link to post Share on other sites
ryechua 8 Posted May 11, 2016 it depends on the batteries you are using. mine seems to last at least 6 hours Quote Share this post Link to post Share on other sites
PRSGuy 34 Posted May 11, 2016 If I use Duracell Quantum batteries I get 6 - 8 solid hours if not more sometimes...I was using rechargeable and they didn't hold up nearly as well. Quote Share this post Link to post Share on other sites
phenix9 2 Posted May 11, 2016 i used alcaline batteries but it was expensive so now i use rechargeable batteries but LINE 6 told me it was not good at all and they do not recommend to use rechargeable batteries if i want to play some very long hours (more than 2-3) with it Quote Share this post Link to post Share on other sites
eklynx 14 Posted May 11, 2016 Also, if my memory serves me, there's a low-power mode if you're not going to be wandering too far from your pedalboard. 1 Quote Share this post Link to post Share on other sites
ryechua 8 Posted May 13, 2016 i've been using these rechargeable batteries and they last 6-8 hours Quote Share this post Link to post Share on other sites
AParedes 2,473 Posted May 21, 2016 ryechua -good to know, haven't tried these. the "low power" mode is easily accessable on the TBP12 (from the Relay G50/55/90 system) as part of the menu. this usually bumps you from 8 hrs up to 10, but does compromise the strength of the output. when in doubt - use the normal output mode. Quote Share this post Link to post Share on other sites
