morelia Posted May 12, 2016 Share Posted May 12, 2016 This has to be some simple mistake. I tried (amp switch) out to Roland HD500X. No processed sound. If I use the tuner to bypass the processing there is signal. Tried the same to mixer. Same result. Using guitar in and mono unbalanced out (tried both outs). It's been working ever day for over a year so I can't imagine what is going one. Is there something obvious I'm missing? Tried with headphones as well. Same result. With tuner on I hear guitar but when off there is no output. (edit) Has had use once a fortnight for over a year without missing a beat. I did read somewhere that there should be no sound when the tuner is engaged. As this is the only time there is a signal passing through could that be a sign of the problem? Quote Link to comment Share on other sites More sharing options...
bartnettle1 Posted May 12, 2016 Share Posted May 12, 2016 I am just guessing here but have you checked your cables? When tuner selected there is audio but attenuated. Not sure why yours suddenly not working, but check cables is first. Quote Link to comment Share on other sites More sharing options...
morelia Posted May 12, 2016 Author Share Posted May 12, 2016 I haven't specifically checked the cable but because they pass signal when I enable the tuner I assume they are all good. Having said that, yes I have checked 2 out of the three cables that I have been using today. Thanks for the idea though. Quote Link to comment Share on other sites More sharing options...
bartnettle1 Posted May 12, 2016 Share Posted May 12, 2016 No worries, I mentioned as the tuner is mono and might only pass thru a broken Mic cable. Also try checking the amp or monitors your using. Hope you get it working Quote Link to comment Share on other sites More sharing options...
morelia Posted May 13, 2016 Author Share Posted May 13, 2016 I've checked the amp (which is new and working perfectly) and the mixer which is also working. All leads now confirmed as working. I used all this gear regularly so I'm a bit stumped. Do these things just go kaput? It's a year and a half old. Is warranty out of date? Pretty bummed if this is just out of warranty and having a major fail. Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 13, 2016 Share Posted May 13, 2016 I suggest you open a support ticket to work directly with Line 6 tech support on this. Quote Link to comment Share on other sites More sharing options...
morelia Posted May 14, 2016 Author Share Posted May 14, 2016 Nope, I figure it out. Just took another person to ask a simple question. Why is it only the first 4 banks? I hadn't thought to check the rest. But the first 4 are my live setup and I have FX Loops in each preset. I just assumed it would auto bypass but it doesn't. The sound just stops at the FX Loop. Seems a bit of an oversight but easily dealt with now that I know the problem. Thanks everyone that offered any help. Quote Link to comment Share on other sites More sharing options...
bartnettle1 Posted May 17, 2016 Share Posted May 17, 2016 LOL We all been there. Glad you found it Quote Link to comment Share on other sites More sharing options...
