Garhel Posted May 29, 2016 Share Posted May 29, 2016 Hi - hopefully a really quick one - when i've assigned 2 or 3 pedals to one switch, it titles itself as "multiple", and i can't find anywhere in the editor or the device itself to change this. I've done a search here and can't find this answered previously. I'm sure it's something simple, but can anyone point me in the right direction? Thanks, Gary Quote Link to comment Share on other sites More sharing options...
FullMotion Posted May 29, 2016 Share Posted May 29, 2016 I don't have the Helix in front of me, but this should be correct... Push the menu button and select control panel. Use the joystick to highlight the graphic for the switch you want to name then press the knob under "Customize". Rename it however you like. Quote Link to comment Share on other sites More sharing options...
Garhel Posted May 29, 2016 Author Share Posted May 29, 2016 Perfect - it's command centre, rather than control panel, but now sorted :-) Thank you! Quote Link to comment Share on other sites More sharing options...
rinkydink Posted May 29, 2016 Share Posted May 29, 2016 Also, if you're running the Helix Editor, at the bottom of the patch selected, click on the "Footswitch Assign" then "Custom Label" above it will appear, then replace "Multiple.." by typing in your new custom label. Quote Link to comment Share on other sites More sharing options...
