Sign in to follow this
PearlyGates59
Create a bank with different configuations
Hi everyone, I'm using my new POD HD500X with a Cornford Carrera connected 4 cable method.
I want to create a bank where I can toggle from a patch or patches where I'm using an FX block and my tube pre from the amp.
Then kick to the next patch where I'm using a POD pre and just using the power amp section of the Cornford.
Then kick to the next patch where I bypass the tube amp and output to my PA, for an acoustic sound.
I have not been able to figure out how to select the proper output mode. When I am using the pre from my amp I'm thinking my
output setup should be combo front or stack front. When I'm using the pod pre I think I should use combo power or stack power.
Those seem like global settings to me, can't figure out how to make them change patch to patch.
Also can't figure out how to mute the tube amp and use the PA for an acoustic patch.
Thanks in advance for any help.
Try posting this in the POD HD forum section. This section is for older versions of POD than the HD. :)
