M5 Set to 100% wet for fx loop. Can tuner on/off function as a mute/send?
luca9583
Hi guys. I'm thinking about setting up an M5 in a parallel fx loop.
I would like to control the send to the M5 via Midi so that when i don't want any effect, the M5 is muted.
Could i use the tuner mute function as a way to "send" audio to the M5 and mute the pedal?
More importantly, where in the internal signal path is the tuner mute inserted? Before or after the fx?
If it's sfter this wouldn't work for delays as the fx would still be running when in mute mode and would jump out when tuner is switched off
