Evorgeloc
XLR out
I have had an issue when taking mono xlr out from 1500 and sound engineer says I'm giving him way too much signal.....is there an adjustment where I can decrease the output from Firehawk 1500 XLR out
Same issue whether I'm running mono or stereo! We need a pad for the XLR outs or a separate volume control. Hello?
Lower the guitar output, in the levels section of the app.  This will lower the level coming out of the XLR.  It will also lower the level of the guitar coming out of the amp, in which case you would need to raise the overall master level of the amp to compensate.
Thank you Sing4LTS - I'll give that a try - I suppose this means I have to go through all my patches and adjust each one?
I had that same problem this past weekend using my Amplifi FX100. I was going from 1/4 mono output to a powered monitor and gave the sound man a link out signal via XLR. After discussing it with him, the sound man just turned down the input trim on his channel strip. I didn't have to change a thing on my setup. Got lots of comments about how good the guitar sounded out front. Sound man should be able to do the same thing on a signal straight from Firehawk.
