Questions For Anyone Who Prefers The Old (pre Hd) Spank 2 And 4 Positions
Frankly, based on that video, I don't know how anyone could prefer the Strat sounds in 1.9 compared to 2.0, but it's all based on personal opinion. But my personal opinion is that the 1.9 Strat sounds in that video sound somewhat lifeless compared to the 2.0 ones. But, yes, the sounds in this video pretty much square with my experience from going from 1.9 to 2.0.
I think the positions 2 and 4 of pre hd had more balls, quack and presence
Yes, you stated your opinion on that previously. The questions I am currently asking you are:
1. Do you ALSO find Spank 1,3, and 5 positions sound better in the pre HD firmware?
2. Overall, are you experiencing results with the HD upgrade similar to what is shown in this video? :
wow dude!
i was just having a mad love affair with jazzbox 4 last night (super 400/neck)
i suppose it depends on what you're looking for, but it was giving me what i wanted last night.
I think the models semi5, jazztone 4, spank and 2 and 4 are  best in pre hd, the rest I think the best in hd, but in this video he compares semi with humbuckin with semi with p90, are really different to compare
Okay, so I think your answer to the 1. Yes/No question is "YES Spank 1,3, and 5 are better in HD" in your opinion,  is this what you are saying?
Trying to narrow it down here to figure out what is going on... have you tried adjusting the volume of the pickups relative to each other in position 2 and 4 in Workbench? I am thinking if the guitar modeled in HD had slightly different height adjustments on the pickups compared to the guitar used in the original modeling it would affect the way the pickups blend in position 2 and 4, and adjusting the relative pickup volumes in Workbench may give you a sound closer to the pre HD version of Spank 2 and 4.
Okay - OTHER THAN THE SEMI , are you experiencing results with the HD upgrade similar to what is shown in the video?
yes to 1 question
I have not worked with the new models in the workbench when you have time try to change Some things, but what you are saying about adjusting volumes in 2 pickpus make much sense, I'll still try it
about the results of video, I think the most improved models, except those already mentioned earlier, but I think that the volumes of the new models were lower,especially the hd strat pickups before were much higher than the magnetic, not now
could answer everything? sorry my english is not very good, sometimes do not understand the technical terms set out here in the forum
is not that has been bad, but in 1., 9, it seems that the jazztone 4 had more bass, more deep, but I'm still in the testing phase, these were my first impressions
wow dude!
hey guys... try this... just did it to mine and position 2/4 sound much closer to the 1.9 type strat...
i changed the taper from audio to linear on the pots.
its still an HD model.. and still subjective... but making this small change seemed to bring them closer.
also, it looked like the default position 2 only had the middle pup engaged... so i turned on the bridge with that model.
anyway be curious to know if this does anything for anyone else.
Hmmm, interesting.
I asked question 1.  thinking that if someone likes position 1, 3, and 5 better in HD but 2 and 4 better pre HD that there is something different in the way the pickups are combining in the HD version, if position 2 has the middle pickup only that would make a HUGE difference. Also, different pots or caps settings in HD defaults could be making the sounds wildly different, I can't connect to Workbench yet to check this or to test adjusting the pickup levels ( have been using HD500 to connect my JTV and still have not gotten around to unpacking/charging the battey to use the Workbench dongle, maybe this week).
I ask question 2. to try to narrow things down in this discussion to questions of taste and/or real problems - if someone is experiencing the same results with their JTV update as those shown in the video and prefers the sound of Spank 2 and 4 in the old firmware then we are probably discussing matters of taste, but if someone is experience wildly different results than those shown in the video this may indicate they are in need of a reflash (or might possibly have more serious problems with their guitar).
Positions 2 and 4 need both middle and end pickup turned on to get the "quack" Strat sound as these pickups are supposed to be wired out of phase.
Yes, 2 pickups have to be turned on for position 2 and 4 Strat sounds, but that sound is not caused by the pickups being wired out of phase, it is caused by the two pickups picking up sound on different parts of the string - probably still called "out of phase" string-vibration wise but not wiring-wise. I have wired my Strat pickups out of phase before (reversed the leads) but this does not give you the classic Strat "Quack/Cluck" sound, it gives you an extremely pronounced hollow out of phase sound that would be of limited use to most people.
Connect to Workbench, choose Spank position 2 or 4 and click the reverse polarity switch to simulate out of phase wiring and you should hear a huge difference.
Here is a quote from one of the Fender.com forums that I think is relevant to this subject:
http://forums.fender.com/viewtopic.php?p=399385
Optimizing Cluck for the inbetweeny positions
"I start with both N and M at the same distance from the strings and then slighty lower (like 1/4 turn) the bass side of the middle pickup. I do the same for the treble side but usually a little lower. I usually do this by ear because you can change a dull cluck into a sharp cluck with a fraction of a turn and i'm usually trying to sharpen up the bass side and mellow out the treble side."
Just to clarify: on Strats, although the middle pickup is reverse wound, the magnets are also installed reverse polarity. Thus, any selection with the middle pickup is IN-PHASE, not OUT-OF-PHASE (but it does kill hum).
Brian May used neck and middle out-of-phase for the Bohemian Rhapsody solo, but it's not his normal sound. Basically, it kills a lot of the low end sound due to the signal cancellation. It doesn't kill it all due to the space between the pickups ensuring they don't pick up the identical sound. Plus, Brian's pickups are in series, not parallel. Out of phase results in a thinner sound than people generally find useful.
Unless you are a boob like me and reverse the leads :P
Did this recently when installing a new bridge pickup, the guitar instantly sounded terrible in position 2 - both out of phase and with twice the noise of either of the pickups alone.
I DID wire it properly the first time according to the GFS supplied wiring diagram - it looks like they may have mistakenly switched the leads at the factory...? Or sent me a middle position pickup mistakenly labeled as a bridge pickup? One of the wires was yellow, usually Fender color coding for middle position as I recall.
http://snd.sc/19EUB9i little sample of strat pos 2 and variax mags, ... really disappeared quack
Firts variax model and 2 part variax mags
Did you try adjusting the pickup volumes in Workbench? Sounds like raising the volume of the bridge pickup a little (or lowering the volume of the middle pickup a bit) may fix the problem for you.
Decreasing the volume of the middle pickup definitely helps bring the quack back on position 4.  It doesn't seem to do as much for position 2, but IMO, position 2 sounds pretty good (although I may favor 1.9 a bit on this).
Other than that, I am loving the new models.  Jazzbox and all!
For me, aside from the acoustic 5 position, the sounds I've been using the most are also the most affected by the 2.0 update,
that is, the neck positions of the jazzbox models, the thinline telecaster neck position and strat 2 and 4 positions.
With my 700 I also use a custom made les paul preset, because it doesn't have the magnetic pickups.
There's not so much to win, feature wise, in comparison with 1.9 so... why am I keeping 2.0?
Well, I loved strat 2 and 4, and I don't think I'm ever going to be able to replicate them with 2.0, but the thing is, after a while,
I'm not so sure I prefer those sounds, that I've used so much and grown to feel at home with, to the similar ones I'm getting
with 2.0.
Up until now, all I've been doing is editing guitar models with workbench and playing them through their associated patches
in the HD500, so I can better notice what has been changed and what hasn't. Sean Halley suggests that we may appreciate
the new sounds more if we listen to them with an open mind, not expecting them to sound instantly right through existing patches
http://line6.com/support/topic/2018-version-20-hd-update/page-4?do=findComment&comment=12649
Well, I understand that, but I still need to hear what's going on and hear the differences. Now it's up to me to redo some of
those patches. Why am I willing to do so much effort when I can simply stay with 1.9 and sound OK? Well, that's where I'm getting to
I love having all variax patch volumes sound the same, in terms of perceived loudness, so it took me a while to get that with
the new models, and had to create a custom bank to replicate the one I had before. One of those patches I created is a jazzbox
with the R-Billy Tron neck pickup, which sounds as woody as the previous jazzboxes did, and another is a strat 2 substitute with
the tone pot about 85% that sounds more mellow and can be an instant substitute (not replica, but substitute) for the former
strat 2 position.
And finally, the reason why I decided to keep the 2.0 is that it's simply more musical.
I did hours of A/B testing yesterday, switching back and forth between the v700 and the JTV-89, and everytime I went back to
the JTV aiming to replicate the sounds on the 700, I came up with some really good sound. Never a replica, but a better version.
Anyway, if I miss the older models, I have my 700 for that, but I bet that, once I've redone some patches, I won't miss the old models
so much.
That said, the JTV-89 custom bank in 1.9 led me to expect to be able to split coils, but instead, I have to use actual single coils for that effect. Will I survive? Yes, it's just that I was counting on this new feature.
Oh, and I want the thinline body back!
On the "undoubtedly better" side of things, I have to say that the new Rick 12 string models are amazing, and the P90's, and the wide range humbuckers, and the LP, and all resonators, and the tone pot response, and... and...
  • 2 years later...
I agree with you! I own a Variax 700 and the sound of Spank 2 is more similar to that of the Variax Standard if you change Taper to Linear. It becomes less neutral and more colourfull. I Think the same applies to T-Model-1.
Thanks for sharing this!
What I personally gathered, is that 1.9 and HD have different frequency responses compared to eachother.
Though HD has more clarity and precense, some of the tonalities aren't present that 1.9 had.
One of those is the tonal aspect of 1.9's spank model which had a frequency response that made 2 and 4 seem a lot more quackier.
I think it's pretty quacky, but yes, comparing 2 and 4 to the magnetics on a 69s, there is a very slight lack of quackiness compared to the magnetics.
Overall, I prefer HD, but the problem with switching between 1.9 and HD is that it changes the applications of your tones, so it "sounds off" from what you've been used to.
Workbench will always be there to help out shape your tones to what you want.
