chillbillyscott 5 Posted June 7, 2016 Is it possible to simultaneously record a dry(DI) track and a wet track without using USB? I'd like to use traditional cables (xlr or 1/4") going from the Helix into my audio interface? Quote Share this post Link to post Share on other sites
bsd512 169 Posted June 7, 2016 The Helix rack has a dry output jack. The floor unit doesn't. I submitted an IdeaScale to route the dry signal to one of the other outputs on the floor unit a little while back. Vote it up. http://line6.ideascale.com/a/dtd/Enable-dry-signal-output-alternative-other-than-USB-7-8/821453-23508 Quote Share this post Link to post Share on other sites
vmoncebaiz 45 Posted June 7, 2016 Yep. There are a couple different ways to set it up without USB. I tend to have the top path 1 handle whatever fully processed sound I want and go into my interface via XLRs. I have path 2 on the bottom us the same input (Guitar or Multi). Then I leave that path empty and set the output to one of the 1/4" sends (or sPDIF). Quote Share this post Link to post Share on other sites
phil_m 4,522 Posted June 7, 2016 If you're OK using a 1/4" out for the dry signal, you don't actually need to use another path. You can just insert a send block as the first thing in your path. Set the mix to 50%, and the dry path from the send block will be the same level as the signal going though the block to the rest of your path. If you want to use SPDIF, you'd have to set up a separate path as mentioned above. Quote Share this post Link to post Share on other sites
Joepeggio 76 Posted June 7, 2016 If you're OK using a 1/4" out for the dry signal, you don't actually need to use another path. You can just insert a send block as the first thing in your path. Set the mix to 50%, and the dry path from the send block will be the same level as the signal going though the block to the rest of your path. If you want to use SPDIF, you'd have to set up a separate path as mentioned above. +1 Quote Share this post Link to post Share on other sites
