hefonthefjords 38 Posted June 17, 2016 Hope someone can help here...Is there any way to assign momentary control changes for the same parameter (for example the gain on an amp sim) to multiple buttons with different values being applied on each different different button press by setting the min and max values equal to the desired value for each parameter on a momentary switch?I just bought a Helix a couple of days ago and after programming and experimenting for a few days and even attempting a full blown rehearsal with it, I pretty much can't find any way to replicate the same signal path for performances I've been using on my X3s without experiencing huge dropouts when switching between presets which will genuinely destroy certain important sections of the shows I'm performing.The only workaround I could think of was to load every effect I normally enable/disable via preset change in a show into one massively complicated preset and then use momentary control changes to reconfigure all the parameters for the sounds I use in realtime, utilizing the mix and level parameters to blend in and out the various effects and applying new volume and gain settings to amp sims etc. otherwise this device is basically unusable to me for performances.Here's an example of what I'm looking to set up; Button 1 - Applies preset's default parameters for all parameters edited by buttons 2, 3 & 4 allowing you to return to where you started without reloading the preset.Button 2 - Sets the mix on a delay block to 45%, sets the Chan Vol of an amp sim to 7.5, sets the Gain of an amp sim to 2, sets the Chan Vol of a parallel amp sim to 0. Button 3 - Sets the Gain of an amp sim to 4, sets the Chan Vol of a parallel amp sim to 0, sets the gain of a TS808 to 3, mix on a Chorus to 25%, mix on a Reverb to 20%. Button 4 - Sets the output Level on both 1/4" and XLR outs +3dB, sets mix on a Delay to 40%, sets mix on a Reverb to 35%I also couldn't find a way to enable or disable a block via control changes either so if anyone knows how to set up either of these functions can you tell me how to do it? I really like the sounds this box can make so I don't want to have to return it and go back to the X3 just because of dropouts between presets... Quote Share this post Link to post Share on other sites
Cattlerancher 5 Posted June 17, 2016 You're looking for "scenes," and no, they don't exist as of yet. 1 Quote Share this post Link to post Share on other sites
ricksteruk 85 Posted June 17, 2016 I'm afraid it's going to be a bit of a struggle for you until "scene mode" or something like it surfaces for Helix. I will be very happy when that day comes! - but there's no guarantee that it will ever be released.. there are many things on the wish list... Please go to Ideascale and add your vote to any idea suggestions for scene mode. However - there may be a way for you to manage until then - but it will take some thought. If your show is really complicated It sounds unlikely you could manage with just 1 preset. But perhaps there are a few gaps in it where a half second gap of silence from your guitar might be ok? If that's the case you could split the show into several presets maybe?? One foot switch can control up to 8 things.. bypasses of blocks or controllers to set max/min parameter values - and this is a good start - but the problem we have at the moment with complicated FX changes is that it is not possible to assign one parameter (say the Bypass on a Delay block) to more than one foot switch. What you can do however is to assign different parameters of the same FX block to different switches. For example - one footswitch could be assigned to bypass/enable the block, and another could be assigned to the mix.. min at 0%, max at 100% (or whatever you need). Then bingo - you have two switches controlling the same switch. You could also put the FX block on a different path with a split block that is controlled by a 3rd foot switch. So there are possibilities - you just might need to think about things in a new way. I've managed to solve *almost* all my switching needs like this.. there's just one or two times when it takes me two foot switch presses to get from one sound to another when there's a lot going on in a preset. 1 Quote Share this post Link to post Share on other sites
hefonthefjords 38 Posted June 17, 2016 I've spent many hours this week trying to do exactly that ricksteruk and I did get very close to having something I could maybe use. There are a few other stumbling blocks I've run into aside from not being able to do "scenes" as cattlerancher describes it.I've had to tie up an entire line of DSP blocks in order to be able to send a cab sim to XLR for front of house and no cab sim to my 1/4" outs for my stage use with amp and cab. This wouldnt be a problem if i could route between the parallel DSP paths more than once but it seems as though that's not possible for some reason.I've made one of those Ideascale thingies to try and get XLR outs added to sends list here: http://line6.ideascale.com/a/dtd/Send-To-XLR-and-1-4-from-Send-Return-Block/827623-23508Thanks for the help. Quote Share this post Link to post Share on other sites
ricksteruk 85 Posted June 17, 2016 I've spent many hours this week trying to do exactly that ricksteruk and I did get very close to having something I could maybe use. There are a few other stumbling blocks I've run into aside from not being able to do "scenes" as cattlerancher describes it. I've had to tie up an entire line of DSP blocks in order to be able to send a cab sim to XLR for front of house and no cab sim to my 1/4" outs for my stage use with amp and cab. This wouldnt be a problem if i could route between the parallel DSP paths more than once but it seems as though that's not possible for some reason. I've made one of those Ideascale thingies to try and get XLR outs added to sends list here: http://line6.ideascale.com/a/dtd/Send-To-XLR-and-1-4-from-Send-Return-Block/827623-23508 Thanks for the help. There's already an idea scale for that! I made one in April.. http://line6.ideascale.com/a/dtd/SEND-Block-to-more-places-e-g-1-4in-for-easy-IR-bypass/818624-23508 Digital Igloo even voted for it so it must be a good idea :) 1 Quote Share this post Link to post Share on other sites
hefonthefjords 38 Posted June 17, 2016 Excellent. Voted for it. 1 Quote Share this post Link to post Share on other sites
