jeebster Posted June 24, 2016 Share Posted June 24, 2016 Hey Everyone, Recording direct via USB with dry signal enabled worked fine up until I tried it again today. I have the Re-amp src (USB7) output set to 'Guitar' and my 1/4" instrument is plugged in, however I get no signal in my DAW. Outputs 1-2 have signal, but nothing on 7 and I tried switching to 8 as well, no dice. I'm using Logic Pro X 10.2.3 and recently upgraded to El Capitan 10.11.5. Is this a known issue with either version? Any help would be appreciated, cheers. Quote Link to comment Share on other sites More sharing options...
phil_m Posted June 24, 2016 Share Posted June 24, 2016 Are you using the Line 6 drivers or the built-in Mac drivers? Quote Link to comment Share on other sites More sharing options...
jeebster Posted June 24, 2016 Author Share Posted June 24, 2016 Are you using the Line 6 drivers or the built-in Mac drivers? Mac drivers. I'm unsure whether I should be using Line6 or Mac drivers at this point. I'm Helix firmware 1.10.0 as well. Quote Link to comment Share on other sites More sharing options...
phil_m Posted June 24, 2016 Share Posted June 24, 2016 I would recommend trying the Line 6 drivers. Here's the link for the beta Mac drivers: http://line6.com/software/readeula.html?rid=6962 Quote Link to comment Share on other sites More sharing options...
ricksteruk Posted June 24, 2016 Share Posted June 24, 2016 Hey Everyone, Recording direct via USB with dry signal enabled worked fine up until I tried it again today. I have the Re-amp src (USB7) output set to 'Guitar' and my 1/4" instrument is plugged in, however I get no signal in my DAW. Outputs 1-2 have signal, but nothing on 7 and I tried switching to 8 as well, no dice. I'm using Logic Pro X 10.2.3 and recently upgraded to El Capitan 10.11.5. Is this a known issue with either version? Any help would be appreciated, cheers. Did you accidentally plug your guitar into the Aux input? I've done that before, and if the preset you use has it's Path is set to Multi input you wont notice. (till you switch to a preset that isn't multi) Quote Link to comment Share on other sites More sharing options...
jeebster Posted June 25, 2016 Author Share Posted June 25, 2016 Did you accidentally plug your guitar into the Aux input? I've done that before, and if the preset you use has it's Path is set to Multi input you wont notice. (till you switch to a preset that isn't multi) Oy, that was it. Thanks for the tip! Quote Link to comment Share on other sites More sharing options...
